6 members (Gdads51, 52Carl, Otto Skorzeny, dwreills, 55shaker, 32Fordpuchoptop), 70 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#442585 08/17/2008 2:25 PM
My brake lights are only working if I have the turn signhals on.
With either turn signal on, the opposing brake light lights up when the pedal is depressed. Both signals work, but without one side signaling, I get no brake lights.
Checked all the obvious, the flasher, it's good - the brake switch, it's good. I'm pretty sure I have connection or my signals wouldn't work.
I'm thinking it may be the switch in the steering column as they both run through there.
Any thoughts?
Avette4me #442607 08/17/2008 3:14 PM
Riding in the Passing Lane
It's more then likely the switch itself.
1972 Chevy c10 Cheyenne Super
You mean the brake light switch?
I have hot on both sides of it when I hold the pedal down.
Avette4me #442651 08/17/2008 5:32 PM
No. Sorry I meant the turn switch.
Thanks man. That's kinda what I was thinking...
Avette4me #442951 08/18/2008 7:09 PM
In case anyone might run into a similar deal in the future, it was the signal switch in the column.
