5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
got a 1969 chavy truck that has a 350 points distributer in it want to to take it out and put in a electric distributer the one im wanting to install has two plugs on it now how can i get that hooked up on the 69 and it just having the one wire points distributer????
if you mean the HEI, one pin is used for power to the coil, the other is for a tach, not used .... don't ask me which is which ohwell
Riding in the Passing Lane
If you have a factory HEI like Red says, you plug the 4 wire conn. from the dist in the back part of the cap connection point. Run a 12 gauge wire from the bat. term. into the cab & scrape some insulation from the pink wire in back of the ign. switch. Wrap the wire around the pink wire & solder it. If you run a tachometer hook it to the tach. term.
1972 Chevy c10 Cheyenne Super
