| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44226 07/13/2003 7:08 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | on the three on the tree transmisions, they started using them in the 50s on til the late 70's right? well in those twenty years they had a bunch of different types and models. did they improve through the years at all? if so, in what areas? would the old AD 3 speeds work just as well as the ones they used in the 60's and 70's?
and am i the only one that likes them?! | | |
#44227 07/13/2003 5:02 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Yes, they are sweet little trannys and really nice if you have the overdrive. I don't know about improvements, but I'm certain someone on here knows.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#44228 07/13/2003 5:04 PM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | the old AD trans is a torque tube driveline type the newer three speed is a slide in yoke and has a lot more parts availible but unsure if it will bolt to an AD bellhousing the newer 3sp is made to be mounted in a crossmember should have the same input shaft splines as the AD trans | | |
#44229 07/13/2003 9:32 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the earlier 3spd's had no 1st gear syncro - then they were fully syncro for trucks 68 on - the full syncro 3spd is direct bolt in for the earlier, prolly right back to start of open drive - I've got the later syncro trannys in both my 57 and 58 drivers - nice Bill | | |
