6 members (RAC1812, HandyAndy, Peggy M, 1955 1 Series, Otto Skorzeny, Bill Marlow), 190 guests, and 1 robot.
Topics128,087
Posts1,055,982
Members48,430
#44226 07/13/2003 7:08 AM
on the three on the tree transmisions, they started using them in the 50s on til the late 70's right? well in those twenty years they had a bunch of different types and models. did they improve through the years at all? if so, in what areas? would the old AD 3 speeds work just as well as the ones they used in the 60's and 70's?
and am i the only one that likes them?!
#44227 07/13/2003 5:02 PM
Oly Offline
Yes, they are sweet little trannys and really nice if you have the overdrive. I don't know about improvements, but I'm certain someone on here knows.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#44228 07/13/2003 5:04 PM
the old AD trans is a torque tube driveline type
the newer three speed is a slide in yoke and has a lot more parts availible but unsure if it will bolt to an AD bellhousing the newer 3sp is made to be mounted in a crossmember should have the same input shaft splines as the AD trans
#44229 07/13/2003 9:32 PM
the earlier 3spd's had no 1st gear syncro - then they were fully syncro for trucks 68 on - the full syncro 3spd is direct bolt in for the earlier, prolly right back to start of open drive - I've got the later syncro trannys in both my 57 and 58 drivers - nice smile
