7 members (moparguy, Chris_Welch, Gdads51, homer52, texas46, 2 invisible), 139 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
I am figuring out some random stuff, and I started wondering: my 1 ton has a straight frame, no hump where the rear axle is. and when I see pictures of 3/4 and 1/2 tons, they have that little hump. so is it safe to say that all one tons have a 'straight' frame, as in, no hump where the rear axle is? and if so, from when till when was that? (mine is 1959). and come to think of it, if anyone has such a 1 ton frame they need to get rid of, send me a pm. not too far away, not too expensive. I'm about 2 hrs south of Memphis,TN.
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
U
U Offline
Fords had the straight frames.
Most all GM light duty have the hump.
Do not know about the newer stuff.
I could be wrong agian.
mmm.. anyone got pictures of their 1 ton frame online somewhere? would sure be helpful here I think
I LOVE MY TRUCK
Here is a 51 1 ton long bed frame photo.
Hope it helps.http://good-times.webshots.com/photo/2744776790103393295FpDREk?vhost=good-times
The 1 ton frame has many differences which would be the thickness of the metal itself, the height of the rail, and the width of the rail. I do have the spec info at home. the 1 ton does not have the hump in the back over the rear axle. If you are interested I have a 3805 1 Ton frame from a 57 Chevy Panel.
1957 3805 Panel
It's not how you fall down, but how you get back up.
I have a 55 Chevy 3800 one ton and the frame is straight. My dad has a 56 Chevy one ton with a dump bed that has the factory recession in it, so it has the hump over the rear axel.
Schweikerts Last Stand
