3 members (GIJOE298, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
how is the spring attached that's on the inside of the lid of the FRAM oil filters? I'd like to take it off to make painting easier
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
I restore quite a bit of these (over 30) and you can't remove them or at least shouldn't. Most of them are welded in place. If they weren't, it would be difficult for the spring to stay in the middle of the lid where it is supposed to be when the lid is tightened down. I always mask off the whole underside of the lid and spring anyway. I never want to chance paint chipping off and getting into the oil supply. The underside of the lid was never originally painted anyway. Wada
I agree with Wada. Every Fram filter I've seen has a spring that's not meant to be removed. Ones that are not welded are retained by bending a tab over the coil closest to the cover. This tab WILL break if you try to bend it. Mask it off and set it in an open tin can to paint it.... that's what I do. Good luck!
Ed
thanks y'all. I would've broken it. I do that a lot. figured I'd ask this time. everybody be prepared for a gazillion questions!!!
I LOVE MY TRUCK
