2 members (Shaffer's1950, 1 invisible), 102 guests, and 3 robots.
Topics128,089
Posts1,056,439
Members48,443
#44206 11/19/2001 6:44 AM
I put a T5 behind my 235 without changing the pilot bushing. Not a good idea. So, yesterday my son and I pulled the transmission to change the pilot bushing. I had read you could pack the bushing with grease and drive it out with hydraulic pressure. Tried it, but it didn't work. Grease kept squirting around the dowel. Then went to auto parts store to rent puller. It didn't fit. Someone suggested using a tap, went to Home Depot but they didn't have anything big enough. Tool guy asked if I had found what I wanted. I said, "No." He asked what I was doing. He then told me a story of using Play Dough instead of grease to force out a pilot bushing. Seems he "HAD" to fix his truck one night and he came up with the Play Dough idea at one in the morning, found it at a grocery store.
Hey, when you are desperate you will trying most anything, right? It worked like a charm!
I got my mechanical advice from Home Depot, free; a 5/8 inch wooden dowel rod from ACE Hardware, 99 cents; and Fun Dough from Michael's Hobby Shop, $1.99 for two cans. The expresion on my son's face when that bushing came out - priceless.
Who needs Sears! smile
grin man you gotta love it huh! I'll have to keep that one in the back of my old noggin! cool
May the force be with you - SoloWookie
solowookie.com
Play dough: not just for eating or sticking in your sisters hair! grin
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
OH man, wish I knew this about a year ago, was pulling bushing from 91 chevy s-10 4 cylinder, tried everything, wound up drilling
it out and using a bushing cutter to finish
the job of getting it out.
jbennett
40 burb
I have always had good luck removing pilot bushings with wet toilet paper. Wet it, pack it in, and smack the dowel(I use a ground down bolt) with a hammer. Add more as necessary. A lot cleaner than doing the same with grease.
