| | | Forums66 Topics128,184 Posts1,057,196 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 234 'Bolter | | 'Bolter Joined: May 2005 Posts: 234 | Has anyone installed one of those univeral 3 speed floor shifters in their 60-66 truck? Currently I have the 3 on the tree and it is a little loose.
I use to love my 4 speed on the floor on my C30.
Is it worth it? Does it work well? Which shifter did you use? Is it tall enough like the 4 speed? (The 4 had a tall shaft and also the high hump).
Thanks.. Russ
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | check with Hurst i think they can provide one with a long Handel . | | | | | Joined: Feb 2008 Posts: 3 New Guy | | New Guy Joined: Feb 2008 Posts: 3 | The 63 1/2 ton that I am restoring has a 3 speed shifter in the floor, but I want to put t back to the 3 on the tree. I need the linkages from the column down to the Trans, do you know where I can find these? The floor shifter works ok, I just want original.
| | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | Check with Classic Parts of America (used to be Chevy duty). They have one fron 1955 through 1987, but not one for the first series (1952) like I have.
Do you know where I might find one for a 1952>
Thanks 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
