0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44180 07/03/2003 11:04 PM | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | The oil pressure on my 216 follows the throttle, at high rpms its maxed out on the gauge. Is this normal or is there a problem?
Thanks | | |
#44181 07/04/2003 3:11 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think at higher revs, say 2000 RPM, the normal warm reading is around 15 lbs or so. 7 lbs at idle is pretty good but it still be a lot lower at idle. | | |
#44182 07/04/2003 1:11 PM | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | Hmmm, Then it looks like I have a problem, what would cause the oil pressure to increase or decrease with the rpms? What maintains the pressure in a splash oil system like the 216? Thanks | | |
#44183 07/04/2003 1:38 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I do not think you realize that the 216s do have an oil pump. The oil pressure will increase with higher RPMs, and drop to very low at idle. I am not convinced you actually have a problem. | | |
#44184 07/04/2003 6:05 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know what the upper limit is that you are likely to reach. Normally, guages are usually designed with there being plenty of room above the likely maximum value. Now, I just bought an NOS oil pressure guage and it has a little tube affair that disorts with the pressure and rotates the dial against a spring.I suppose that the spring could fail or change characteristics to give you higher readings.
The 216 has a small oil puimp that feeds the mains, cam bearings, rocker arms and fills the dipper troughs. The oil pump itself has a relief valve that opens at, I think 60 lbs. Also, there is a small plate on the driver's side of the block that contains the oil distributor valve. If that valve stuck closed, it would stop delivery to the rocker arm and the rod supply nozzles. That might cause the higher pressure and that problem would be vey bad for the motor. | | |
#44185 07/04/2003 6:22 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Truckernix is real close to the lbs. my 216 runs. She's got 67,000 miles and I run 10W30. At startup on a cool day she'll show about midway between 15 and 30 at higher revs and about 15 at idle. Once she's warmed up good, about 7 at idle and a little under 15 at revs.I've never seen the guage top out at 30,maybe if your runnin' heavy oil and it's cold out. | | |
#44186 07/04/2003 10:14 PM | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | I have 20w50 high milage oil in mine. It reads about 10psi when idling and gradually pegs out at 30 with throttle full open. | | |
#44187 07/05/2003 12:26 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is one of the truly amazing things for me, was to see just how fast the oil thins as it warms up. With all the hoopala about how great modern oils are, that 10W30 acts like 10W when cold, and 30W when hot, these old 216s point the way to the real truth! | | |
#44188 07/08/2003 8:18 PM | Joined: Jul 2003 Posts: 2 Junior Member | | Junior Member Joined: Jul 2003 Posts: 2 | Originally posted by Itza46: The oil pressure on my 216 follows the throttle, at high rpms its maxed out on the gauge. Is this normal or is there a problem?
Thanks I had one of those motors in a '51, and I NEVER had pressure like that, even with 1/3 STP! You must have a good one. Also, I'd have sworn it had no oil pump, but then, when it finally quit I just threw it away without looking inside & put in a 327.
Ken Riverside, CA
#44189 07/09/2003 1:16 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I ran 20W50 in my 216, when warm it ran about 15 psi at speed, 5 to 10 at idle. I wonder if someone put a 235 pump in yours. Got a picture of the passenger side of the engine so we can be sure it's a 216, and not a 235?
Fred 52 3600 69 C-10
#44190 07/09/2003 2:48 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | John, The oil pressure you are experiencing is normal for a 216. Cold it will be around 30 lbs. When hot 10 or below. This engine only needs about 3-5 lbs to keet bearing separation. 10w 30 is fine. Change it frequently with or without an oil filter.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#44191 07/10/2003 11:11 PM | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | Thanks for the info guys. Fred T, I( dont have access to to a cam at the moment, what tell tell signs would I look for on the rt side of the eng?
Thanks | | |
