2 members (Mike Roache, walter74), 110 guests, and 2 robots.
Topics128,049
Posts1,055,740
#441822 08/15/2008 2:13 AM
got a 350 engine and i need a distributer and i got a good used 283 distributer hanging on my wall out of a mid to late 60s 283 can i sue that and it be the same as to me going and finding a distributer for the 350 just asking if it would work and be the same
i believe they are the same.
you can even use a big block distributor in a smal block, and vice versa.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
ok thank you i always heard that everything was pretyy much the same with the 283 s 305 307 327 and the 350s like intakes distributers and valve cover , manifolds and all was really sure thow.
Yes, it will work. Pretty much all Chevy 90 degree V engine dizzys are the same, with the tall decks being 1 exeption. I beleive you could even use a V6 dizzy with minor alterations.
Bill Burmeister
That's interesting Bill. How would you alter a V6 distributor to work on a V8?
Confused...
~Jim
The story is a little more complicated than just swapping any small block distributor into any of others. But you should be able to use any points type in any motor that does not connect the distributor to a computer.
Once you get into the later HEI stuff, and the more recent stuff interfaced with the computer, they may still physically swap, but making them work could be complicated.
So Bill, I have a bunch of V-8 HEI distributors I'd like to convert for use in some of my old trucks. Do you know what I need to alter to do that? I was figuring pull out the six and drop in a V-8...
About the only part of a V-8 HEI you can use in a V-6 will be the basic housing casting, the module, and maybe the vacuum advance. You'll need to alter the length of the shaft and/or the position of the drive gear, fit a 6-lobe reluctor and pickup coil, and probably do some alteration to the centrifugal advance curve. The distributor cap and rotor are different, too. If you're using the coil-in-cap dizzy, the coil should interchange from 6 to 8 cylinder engines. I do that alteration occasionally, but I've got a machine shop and a distributor tester handy, plus 35 years' experience with the HEI systems under my belt.
