4 members (Hanks custodian, 3800GUY, Bill Hanlon, Ponchogl), 97 guests, and 1 robot.
Topics128,113
Posts1,056,580
Members48,448
#441459 08/13/2008 11:47 PM
1 Offline
as far as my hood goes i'm leaving the side panels off of it and wondering what to use to now latch the hood down? second ? is does anybody know where to get replacement sheetmetal at the rocker panels for a 1946 chevy 1/2 ton panel also same truck for the hood ?
thanks in advance for any help
46 panel,
Never tried to accomplish that but went and looked at mine. Maybe you could rig a steel rod though the hinge joint on side panels to slide like a barrel bolt into a drilled hole in the beltline. The holes wouldn't be visible until you opened the hood. As far as the replacement panels I made most of mine. Some panels can be found at old truck suppliers like Jim Carters/American/LMC?Dixie. Ray Stanley at Wheelwright Restorations could probably make if you can't find. By the way Welcome to the Bolt! Have fun and good luck
Dan
