4 members (Gdads51, Joe H, Otto Skorzeny, Gray_Ghost), 99 guests, and 5 robots.
Topics128,065
Posts1,055,865
Members48,428
#440553 08/11/2008 3:31 AM
What is a spotweld sealer? silcone, lead, soldier?
My 55-59 ASSY Manuel showing a spotweld sealer # 381924, sealing compound 466949. I found these # in my assy manuel sect 1, sheet 139
I am looking at replacing the cab rear skin as it is the only way to get the entire right side. Mine is severly creased all the way up the cab corner to about where the gas filler hole leval. It also has some buckling on the back of the cab, not to bad there though.
Most of the spot welds on the door frame and 6 or 7 across the botton at the back of the cab are already broken. I can see light between the back /floor & it's obvious on the door frame/rear skin.
Brad
the "spotweld sealer" they call out in the manual is unlikely to be available even at the factory, but it would be a seam sealer that would stand the heat of spot welding ... silicone probably wasn't invented then, lead melts at relatively low temps, and isn't a "sealer" ..... soldier?
check your local body work supply place for seam sealer, oughta do the job
oops....SOLDER, acid core maybe?
The picture close up looks like something between the roof cap and rear panel as well as a 1/8" bead of something else.
Brad
sealer is sealer, all the joints/seams got some type of sealer - cored solder isn't used in body work, acid core solder is for radiators, lead [solder without the tin] was used to fill [smooth over] welded joints, as in the cab roof, with a paste flux
seam sealer is what you want for what you need to do, available from any body supply place
Flxible #440781 08/12/2008 12:31 AM
Not trying to quibble but it was solder, probably 60/40 or 70/30, as called for repeatedly throughout the manuals. Not sure what they used for flux in the 50s but in the 70's it was Ruby Fluid. Still available and the very best for tinning steel... in my experience.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
http://solutions.3m.com/wps/portal/...LECFTDQCEK3_nid=GSWMS8NB1Nbe6DTWTJQPBBgl 3m makes some excellent product's there seam sealer is great .
Thanks Old dog
Now to pick one .....
Brad
Fast-n-Firm
