2 members (Danielbolt, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
59 1/2 Ton Stock new harness with ballast resistor out of the picture and a new Mini HEI with external round coil. Not running yet as I am finishing wiring.
In checking the new harness, I had no head lights etc so I realized that I had not affixed the wire from the headlight switch up to the ammeter. I looked up under the dash and saw it was off. I pulled the gauge assembly to hook it and the instrument bulbs etc into the gauge panel. My instruction sheet says the red wire goes headlight switch to C side of ammeter gauge and the black wire( direct from top of starter) to the D side of the ammeter gauge. Hooked up battery with no issues and BINGO I checked headlights and I was good.
Disconnected battery and Reinstalled gauge panel and when I touched battery cable to post...SPARK short.... I pulled the black wire from ammeter and I can hook cable up. Foot stomp circuit still good.
Did I cook the gauge or somehow create a dead short in it? I rechecked to determine that I had red on one terminal side of gauge and black on the other.
Ralph
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
Riding in the Passing Lane
An ammeter passes current through it. It is not grounded. It is highly unlikely to be shorted internally. Your short must be in the circuit the black wire goes to. Touch the black wire momentarily to the red. If it sparks the short is in the circuit. Do not hook up to the ammeter till you solve the problem. That much current can fry it.
1972 Chevy c10 Cheyenne Super
Wow, As I started to sort this out I discovered the horn relay was the culprit. It was VERY hot and somehow had failed. It will be replaced after I check to see if it was wired in correct.
~ Rasman
1971 Chevy C10
"Old Yeller"
1959 Chevy 1/2-Ton
Be sure to check the wire that snakes up the steering column to the horn button. The horn relay is only a dumb slave...it closes when commanded to do so by grounding the column wire through the horn button itself.
Your horn probably doesn't 'toot' either, other wise you would have heard it, right!
Stuart
You are right about the horn. I do not have the wheel on but I am gonna check to see if I mashed the wire and caused some issue.
~ Rasman
1971 Chevy C10
"Old Yeller"
1959 Chevy 1/2-Ton
