| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | hey guy's i know the topic of hei wiring has been wrung out like a dog with a bone ,but here's one i could not find any thing about in the search section .say you have a 61 gmc ,point ignition .has a resister wire in the harness ,what will happen if you put a stock gm hei in it as is ?would you have to do any thing to circumvent the resister wire ? just curious .i put one in without doing any thing to the wiring . | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i put a HEI in my '73 and took out the resistor and used that wire to power a relay then battery power to the relay with a fuse then to the HEI. the resistor will make the HEI not get enough power. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive seen them run using the resister wire but it's not good. I tie into the pink wire on the back of the ign. switch & run a 12 gauge wire to the HEI. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
