5 members (kades51, Hotrod Lincoln, 1955 1 Series, TexasA&M48Truck, CandoBrent), 147 guests, and 3 robots.
Topics128,106
Posts1,056,211
Members48,436
Hi,
Can someone tell me what kind(and how long)of shock absorbers go under the 1959 Fleetside? Mine doesn't have any under it so I can't meassure or compare them.
Kind regards, Pancho
1959 Chevy Apache 3200 Fleetside
1957 Buick Century
1977 Ford F100
Monroe Sensa-Trac part # 37188, also Sears # 83634. same shock, different number.
Bill Burmeister
@LONGBOX55
Are any modification necessary to mount the Monroe Sensa 37188?
Do you know new original style shock absorbers?
EDIT:
How do I know if my old shock absorbers needs to be replaced?
'59 Apache
'67 Mustang
the original 'spiral' type isn't available
listed for the application:
rear shocks - Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060
front shocks - Monroe 3100 [each] or Gabriel 82047
The Monroe I listed should fit, no alterations. It's a direct fit aftermarket. I got both numbers from the Monroe Master Catalog.
Bill Burmeister
Hi Bill,
And thank you again!!!!! You are a great help.
Regards, Pancho
1957 Buick Century
1977 Ford F100
