| | | Forums66 Topics128,175 Posts1,057,119 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 9 New Guy | | New Guy Joined: May 2008 Posts: 9 | The front leaf springs on my 33 half-ton truck are flat, with no upward arch. The shackles are not vertical to the ground. Is re-arching the springs a good option? Are there specs that the suspension guy should use when re-arching? Your comments and help are appreciated. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | It depends a lot if you are building a show truck or just want a casual driver. Back in the 50's and 60's we used to take the main leaf and put it in a hydraulic press and press the leaf between two blocks every few inches until we got the desired arch. It would last for several years of driving over rough country roads. Spring shops can re arch them or you can buy them at Eaton Spring. It all depends on how much money you want to spend. http://www.eatonsprings.com/ | | |
