2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
im sure some people has done this but id like to know what all is invaolved and and how hard this is going to be to do this have a 1957 chevy 1/2 ton truck has the original 235 6 want to take it out and put in a chevy 350 but if possible id like to leave the 3 speed on the colum trans in it can i do that way and can anyone tell me this process step by step of changing the 235 to the 350 and help be appricated thanks jamie...
This is a common swap and there is a lot written on it in this forum. I'm not sure if anyone has a written step by step procedure. Since that year truck came with a V-8 you are basically doing a stock installation. Nothing from the 235 can be used for the conversion except for the clutch and that depends on which V-8 flywheel you obtain. You will need a V-8 bellhousing, flywheel, front motor mounts, ignition switch, exhaust system, throttle linkage, pulleys, hoses, and all the other V-8 components. If you send me an email direct and I can provide you with a spreadsheet which lists all the parts needed with some sources & estimated costs for the conversion.
Fred
Riding in the Passing Lane
Ive done a couple of them & it,s very rewarding. They even drive better. The v-8 is lighter in weight & the weight is further back. I can't add much from what rfs said but if you plan on adding power steering in the future you may want to use a engine mount kit that uses the center mount. The kit for the front mount has got very expensive I noticed in the latest catalog.
1972 Chevy c10 Cheyenne Super
