| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 9 New Guy | | New Guy Joined: Apr 2008 Posts: 9 | Hi, Can someone tell me what kind(and how long)of shock absorbers go under the 1959 Fleetside? Mine doesn't have any under it so I can't meassure or compare them.
Kind regards, Pancho | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Monroe Sensa-Trac part # 37188, also Sears # 83634. same shock, different number.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | @LONGBOX55 Are any modification necessary to mount the Monroe Sensa 37188? Do you know new original style shock absorbers?
EDIT: How do I know if my old shock absorbers needs to be replaced?
'59 Apache '67 Mustang
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the original 'spiral' type isn't available
listed for the application: rear shocks - Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060 front shocks - Monroe 3100 [each] or Gabriel 82047
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Monroe I listed should fit, no alterations. It's a direct fit aftermarket. I got both numbers from the Monroe Master Catalog.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 9 New Guy | | New Guy Joined: Apr 2008 Posts: 9 | Hi Bill,
And thank you again!!!!! You are a great help.
Regards, Pancho | | |
