| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Question: I am setting up a Fenton dual carb intake. Do I need the thick black insulators between the carb and intake manifold? Also, if the insulators are recommended, do I still need to install a standard gasket? or will the insulators suffice without a thin gasket. THANKS! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Johnnyrock70,
The insulators are thermal barriers to help keep heat out of the carburetors and help prevent percolation of the fuel.
The last Fenton dual setup I worked on had the insulators installed. Gaskets were used on both sides of the insulators, making sure the vacuum port in the base of the carburetor wasn't covered and had free access to manifold vacuum.
Some folks run the insulator naked on the manifold and gasket the joint between carb and insulator but I have never seen a 'no gasket' situation.
Stuart | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The carbs will leak without a gasket. They might even leak with a gasket, but you have a better chance of no leak with the gasket. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yup, gotta have the gasket. Also, you don't neccessarily have to use the factory spacers. I made my own out of peice of red oak, then sealed tham to keep the gas out of them. They work great. Read about that in Hot Rod a while back, anly thay used mahogany. I beleive that either Summit or Jegs sells them to fit under Holley 4 bbls that are made of wood as well.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I've had a wooden spacer under the carb on my y-blocks for years. I didn't realize it was an accepted practice. I've been telling people I learned it from Jeff Foxworthy. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Now if you use a wooden carb spacer on your stovebolt....
You you might be a redneck .......
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | If you need some spacers, let me know I've got a couple I'm not using. George | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I would guess that you are installing two single BBL carbs. When I installed my dual Holley Webers, Tom Langdon told me that I did not need the spacers between the adaptors and the manifold. So I didn't and just used gaskets. Worked fine. | | |
