1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43894 03/30/2004 1:40 AM | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | Last fall I purchased a 1969 Sedan Deville. 110k one owner. The only thing that is not original is the electronic ignition. It has a Napa "brain" that looks like the Chrysler one in my Dodge.
Here's what happens: It starts easily, and runs smoothly. For about 20 minutes, then it will cough,sputter and finally backfire so hard to litterally blows the seams apart on the muffler. The first time I thought it was just a fluke. So on goes a new muffler. I'm on my third muffler and getting very tired of this. :mad:
The timing is set correctly; new plugs,wires,cap and rotor, fuel filter and coil. Can the pick up module in the dist go bad? I wish it still had points! It came from the factory that way; good enough for me!
Also, it has 2 ballust resistors. One at the coil and one on the firewall. This too seems strange.
Any ideas? :confused:
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
#43895 03/30/2004 6:10 PM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Is it a 429, or a 472 engine? I think either one can be upgraded with a HEI ignition system for a 500 engine from about 75-up, and you can pitch that aftermarket setup. All that's required to make that one work is a heavy wire from the ignition switch to the distributor, (about a #10), to replace the resistor wire used on the point-distributor model. No ballast resistors, or oddball parts to worry about! It should be a drop-in fit, as the 429, 472, and 500 engines use the same basic block setup. Jerry
#43896 03/30/2004 6:55 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | As HRL said, if you're not worried about car-show snobs, convert to HEI. One consideration is the rotation of the distributor rotor. Unsure if caddy engines turn clockwise like a chevy, or counter-clockwise like a Pontiac. Figure out which way it turns and get the corresponding distributor. Not sure if you'd have to use a distributor out of a caddy, or if another GM unit would work. Compare shaft, gear and oil pump drive tang dimensions on your distributor to the candidate HEI unit. You'll then have to re-curve the HEI to get the optimum spark advance for your engine. Still not a big problem.
I've used 14 gauge wire to power HEI ign systems up to 5,000 RPM. Don't wanna turn a stock-rod caddy engine much past that anyway. HEIs only require one wire from a switched 12 volt source to run. Most important thing is to eliminate ballast resistors or resistance wire in stock distributor power circuit(s). Other slight wiring mods may be needed to get power from key to HEI unit during cranking and run positions of key. Or you could convert a stock points-style distributor with a Petronix kit for a stock appearance. Either way, we can talk you thru it.
good luck
HRB (aka CH)
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#43897 03/31/2004 10:23 PM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Got a little firsthand experience with this one! The Caddy distributor has a different housing height than a Chevy, and I think it's a left-hand rotation, also. The shaft length is the same, but it has a different dimension from the block to the top of the distributor. You'll need a Cad distributor, probably from a 500 CID engine. If one isn't available from a wrecking yard, NAPA, or some other professional-level parts store probably has rebuilt units available by special order. Jerry
#43898 04/01/2004 1:39 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i see cad heis on ebay sometimes. | | |
#43899 04/01/2004 3:43 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | T.Mott,
See no need to worry about HEI. Get one out of Caddy in the local junkyard, drop it in and live happy with it. I used it in a bunch of cars, both of mine and from some fellows, and all I can say is that it is just the more reliable sotck ignition system I've ever used. Just get one for the intended use and no problem. But to be honest with You, I'm not sure about blaming your ignition system for the misfire. Some other problems may be going on. Are You definetively sure there is nothing else wring with it? Just imagine if it's not the lifters i.ex, weak valve springs, You say the engine runs smooth cold, then gets hot and starts misfiring. Is carb problems totally out of question? Guess it's a q-jet, huh?
Alexandre Garcia
