| | | Forums66 Topics128,186 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | My 59 SM420 transmission is missing the speedo drive gear and Carter has some. I know the axle ratio but how do I determine the number of teeth on the speedo drive? They say they need that info to matchup to the bucket of used ones. Its 3:90 diff. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Let's see... a 4:56 is 13 teeth, a 4:11 is 12 so I guess it would be a safe bet that you need an 11-tooth gear... but that's only a guess based on what I know.
Now that I've gone on record I'm sure someone will be by shortly to correct me. | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Thanks Woody. I actually started thinkin about my diff and realized I was not at 3:90. That is my old MGB rear axle. Too many projects! So I went out and jacked up a wheel on the 59 and counted. It is really the 4:11. So if 12 teeth for the speedo gear is correct for a 4:11 I can order one from Carter now. Appreciate the jogging of my cluttered project memory. Ralph | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Rasman, what does JC want for the gear?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Denny & Woody, They are gonna call me back if they have any for a 4 speed. Around 30-40 bucks. They told me they do NOT have any for a 3 speed for certain. Ralph | | |
