1 members (Bill Hanlon), 137 guests, and 9 robots.
Topics128,078
Posts1,056,027
Members48,433
#4385 03/25/2005 7:15 PM
This may be a dumb question, but are these cranks interchangable? Is is just bore difference between these engines or stroke as well? Are the rod journals on the crank different diamaters? The reason I ask is I bought a 261 with a claim of recent rebuild. Had been ran since and was aware of "rumbling" noise. Pulled the head and pan. Haven't torn down completely yet. Everything looks good and like it was recently rebuilt but extremely excessive clearance rod to crank on every single cylinder. More than wear could accomplish or wrong bearings. (You can move every rod back and forth by hand.) Any possibility of someone using wrong crank?
Thanks in Advance,
Steve O.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#4386 03/25/2005 8:23 PM
Nifty 50,
The 1953 CHEVROLET SERVICE NEWS states with regards to the the new 1954 261 cu. in. Heavy Duty Engine "The same stiffer structure crankshaft of the regular 1954 truck engine [235 cu. in.] is used, providing the same 3 15/16 inch stroke." and later "The connecting rods (on the 261), which have larger sections for increased rigidity and strength [than those used on the 235], retain the same 27 degree oil jet hole for cylinder wall lubrication and use identical insert-type big end bearing and rod caps as the regular production engines."
Tim
#4387 03/25/2005 9:13 PM
Thank Tim, then I have to change my thinking, maybe a too agressive gring on the crank journal and wrong sized bearings.
1950 Chevy 3100
261, 4 speed
Purchased 1977
#4388 03/26/2005 3:50 AM
From what I've read from previous posts, the cranks are the same, the rods are heavier.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
