0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43805 10/23/2002 2:22 PM | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | Does anyone know what the timing for a 71 250 Six Cd. is? Thanks for your help  | | |
#43806 10/23/2002 2:39 PM | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 | I think its 4 0r 6 BTDC. Someone will know.
57 3100 235 3 spd
#43807 10/23/2002 8:05 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | 4deg. BTDC w/vacuum advance plugged.
Buzz'n Half Dozen
#43808 10/23/2002 8:59 PM | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | Thanks  | | |
#43809 10/24/2002 8:09 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Rins better if you set it to total advance of 30 degrees or so . substantial increase in power and usually runs a bit cooler too .
This worked out to almost 10 BTDC in my 230 .
There should be _no_ vacuum coming down the advance pipe @ idle if all is well with your carby
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
