| | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Several months ago I stumbled across a thread about this swap but no luck in finding it again.  Both have springs outside the frame but beyond that does anyone know if this is a bolt in swap? Jim | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | It is not a bolt in, but is very doable because both have open drive shaft rear. I suppose you do realize that you will have 8 lugs in front and 6 in the rear. Spring seats will have to be changed which requires some welding. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The 1/2 ton TF rear spring pad spacing is very close to the 3/4 ton AD and will bolt in with no mods. I considered this swap on my '52 3600. However the pad inclination on the TF rear may not give you the exact pinion angle you want for the AD. Make sure you check it. You could shim it if you don't want to mess with relocating the pads. | | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Thanks for the replies. This is a driver but it needs brake and suspension work. I'm thinking a 1/2 ton front axle with the TF rear. Fairly simple swap that will give me better wheel choices, less expensive brake parts and 390 gears.
Jim | | |
