3 members (UtahYork, Nuts&Bolts, Bill Hanlon), 30 guests, and 4 robots.
Topics128,014
Posts1,055,324
Members48,419
#43805 10/23/2002 2:22 PM
Does anyone know what the timing for a 71 250 Six Cd. is?
Thanks for your help eek
#43806 10/23/2002 2:39 PM
I think its 4 0r 6 BTDC. Someone will know.
57 3100 235 3 spd
#43807 10/23/2002 8:05 PM
4deg. BTDC w/vacuum advance plugged.
Buzz'n Half Dozen
#43808 10/23/2002 8:59 PM
Thanks wink
#43809 10/24/2002 8:09 PM
V
V Offline
Rins better if you set it to total advance of 30 degrees or so . substantial increase in power and usually runs a bit cooler too .
This worked out to almost 10 BTDC in my 230 .
There should be _no_ vacuum coming down the advance pipe @ idle if all is well with your carby
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
