0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#437758 08/01/2008 2:11 AM
Ok guys and gals adjusting the valves on the old girl and found two bent push rods, one intake and one exhaust.(not the same cylinder) anyone have a part number or a couple of good used ones to sell? my local car quest only shows two, one 10.812 long ane 11 and something. the ones I have are 10 1/2" long and I'm afraid 10 13/16" wont work. Thanks in advance!!!!
1954 235 (supposed to be out of a truck)
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
You can straighten them if you need to, they are mild steel.
The pushrod length depends on which lifters you have in the engine.
Paint & Body Shop moderator
4ontheFloor #437840 08/01/2008 8:04 AM
Did they bend in the engine or did you step on them. If they bent in the engine, I would sure be concerned about stuck valves.
crenwelge #437874 08/01/2008 1:56 PM
Dont know how they got bent????? engine been running fine, removed valve cover to fix oil leak decided to go ahead and reface rocker arm tips and set valves. fired up before installing valve cover and noticed them. my guess they were bent and reinstalled when engine was rebuilt.
Ex Hall Monitor
Ex Hall Monitor
Chevs of the 40s lists two for the 235. One is "all except powerglide" the other is with powerglide. They don't list lengths. You might give them a call for details. The pushrods I got from my FLAPS measure 10 7/16" & work great with the 40 & up solid lifters.
Tiny #437976 08/01/2008 8:08 PM
Thanks..I found some at jim carters, still trying to get them local though.
4onthefloors comment about straightening the push rods brought back memories of a friend about 25 years ago who had a few bent push rods, and it was a saturday night. no parts stores were open, and he wantd to cruise the beach. so he hammered them straght, and it ran fine.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
RATRODKING #438032 08/02/2008 3:01 AM
could not get them local so ordered them from jim carter, looks like a melling part number.
one more ouestion though, what are you guys setting the valves at??? I have one book that says .006 intake and .013 exaust, but I have another book that says .016 on the exaust (I think)recomendations anyone????
Ex Hall Monitor
Ex Hall Monitor
Tiny #438100 08/02/2008 3:12 PM
Thanks guys!!
