7 members (KEVINSKI, ronsway, Otto Skorzeny, Greg_H, 1955 1 Series, TrknGMC, TooMany2count),
157
Mod | | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43778 04/02/2004 3:28 AM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Hi, I am tearing down, and cleaning up a 1957 235 engine to put in my 1949 Chevy pick up. The engine was rebuilt 12 years ago by a local machine shop & never placed into a vehicle, or ran.
I've ran into a problem. The steel oil line that comes from the oil pump, and goes to the oil jacket on the block, has damaged ferrels, and the brass nuts are dammaged. Someone cranked down so hard on one of the brass nuts that it was pulled over the ferrel and ruined it. I want to replace them, but the size is odd. 7/16. No one around here has anything like that. The steel line is not damaged.
I know I can't be the only one that has ran into this problem. Any of you Stovebolters have a suggestion? Thanks!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#43779 04/02/2004 4:44 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | kthomas I would head off to the local plumbers supply house (not home depot or lowes) but the place that all the plumbers buy their supplies. You will need to remove and replace both ferrels and nuts. My guess is that they will have what you need. If that fails then drop me an email and I will check with my old employer and see if their machine shop has some in stock.
Good Luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#43780 04/02/2004 5:51 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I was able to get them through my local parts store. They carry Edelmann brand. The ferrel part number is #160700, and the nut is #161700.
See the USA in your vintage Chevrolet! My Blog | | |
#43781 04/03/2004 4:51 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | WOW Dave !!!!
You actually found those? I had ran into the same problem and looked high and low. Even Patricks did not know where to get them. I looked at the output of the pump and it is 3/8 and when it goes into the block it is 3/8's. So what I ended up doing is getting some 3/8's steel line and new brass and bent it like the original. I even went to the junk yard to find one. The 53->54 and the 55->62 235 tubes are different.
When looking at this, it will only flow with smallest diameter which is 3/8's I don't know why the put the larger tube from the pump to block.
Do you?
Brent | | |
#43782 04/03/2004 6:17 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If any one needs any of these I had to buy 10 of each so I can spare a few.
#43783 04/04/2004 1:42 AM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Well, thanks to all who replied. I was able to find them at a NAPA store.
