| | | Forums66 Topics128,161 Posts1,056,956 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43760 06/05/2004 1:08 AM | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | How do I keep original oil pressure gage when installing 235 (55 235) to replace old 216? How do I keep original water temp gage? Can I use original vibration damper with 5/8 pulley? Can I use or buy short shaft water pump with 5/8 pulley? Do I have to buy an oil pressure gage to mount under the dash ? These are old questions but they are sincere ! Much Oblige ! rfortn @AOL.COM
rrf
#43761 06/06/2004 11:39 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For the oil pressure gauge, use one for a GMC and it will have the correct range. A decal set can give you the correct color too. I think that you can get a temperature gauge good for 220 from around a 1953 model. | | |
#43762 06/07/2004 5:51 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used a '54 Chevy oil pressure gauge by drilling out the rivets and swapping the faces with my old gauge, it looks factory and the needle color matched the rest.
For the temperature gauge, go to a large hardware store and buy a 1/2" male NPT to 3/8" gas flare female brass adaptor, and screw it right in to the hole in the thread. The gauge tube is a 3/8" male gas flare thread and seat. No teflon tape or sealer should be necessary.
#43763 06/07/2004 3:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | For the dampener, you can use the one off the 216. You will probably need to get a redi-sleeve to put on the shaft where it seals, there is usually a groove cut in the shaft from the old seal.
Fred 52 3600 69 C-10
