3 members (54farmtruck, treegrower, 1 invisible), 74 guests, and 1 robot.
Topics128,214
Posts1,057,484
Members48,473
Junior Member
Junior Member
Any suggestions for installing a donor gas tank in the rear of a 52 1/2 ton truck? I saw a post regarding fatfenders using a chev van 30 gallon tank, but wondering if it may be too big, or heavy when full. What other tanks would be a good fit?
Will I ever get my truck done???
http://www.3cware.com/myoldchevy.cfm
Someone makes a rear mount tank kit for 47-54 GM trucks, seen a article in streetrodder magazine about it. It looked like it would work in older trucks also, might be pricey
Apprentice
Apprentice
hey chevy lover- i looked around for a good while only coming up with stainless steel tanks for $400-$600.
i finally got a 68 or 69 F*&d mustang 18 gal.tank from a OEM supplier on the internet for around $160 plus $40 or so for a sending unit. i sealed it and painted it.
i doubled up 16 gauge sheetmetal a fabbed up a skid plate/ resting spot for my airbagged suspension. I used angle iron to string it across the rear frame. i plan on using either a hidden hitch or strengthening up the rear of the frame just in case of a rear hit.
i am hotrodding and not using the original gauges because the sending unit will obviously not work because of the resistance differences.
i have not put the bed back on yet so i don't know how i am going to put the filler. i am hoping for a hidden behind the tag filler but i think i could also go in the bed fill.
hope i answered any and all ?'s
benzdoc
ODSS President
ODSS President
1 gal = 8.33 lb, 8.33 X 30 (gal tank)= 249.9 lbs.
~ Cosmo
1949 Chevy Half Ton
