3 members (Shaffer's1950, sron48, baldeagle), 68 guests, and 4 robots.
Topics128,015
Posts1,055,334
Members48,419
#43748 09/13/2004 6:36 PM
my truck will sometime die when at high-way speed and then will re-start by itself, does not do it a lot,,and sometime I get a faint back-fire,, I have noticed that I have a small crack in my vent hose going to the gas tank, would that cause it and also could this be some type of vapor lock, it is weird that you can drive for many miles and it may not even do it,,the truck is a 54 235 engine with mallory electronic Ing........it stalled on the way home from the meet , went from 60 to about 35 and then fired back up and no more problem, thanks for any and all suggestions......Fred
Redryder pix
My Hotrod
#43749 09/13/2004 7:49 PM
Could it be an electrical short somewhere that cut out the ignition temporarily? I typically attribute a sharp stall and restart to an electrical problem. Sputtering and stalling is usually more of a sign of a fuel problem.
Did you have the clutch disengaged when it restarted or was the trucks momentum acting as a starter?
#43750 09/13/2004 7:54 PM
53 chevy, no the clutch was not engaged, it re-started by its on momentum, I think it could be electrical also but would not know where to start..thanks for your response,,Fred
Redryder pix
My Hotrod
#43751 09/15/2004 5:53 PM
Big Bolt Shop Curmudgeon
Fred, I'll join with the vote for the electrical/ignition problem.
A sudden and total loss of power (engine run) followed by later restart can, on rare occasion, be the result of fuel starvation. But, that is usually more intermittent and residual fuel will usually allow some irregular running or sputtering.
I don't know nuthin' about fancy electronic ignition systems, so you are out of my league there.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#43752 09/15/2004 11:24 PM
Check inside the distributor for any wires that flex when the vacuum advance moves. Those wires have a nasty habit of breaking the conductors inside the insulation, and interrupting the circuit under the proper vacuum and load conditions. The stock HEI ignition was notorious for flex wire problems with the pickup coil, and it's possible your aftermarket ignition system has something similar.
