| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43748 09/13/2004 6:36 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my truck will sometime die when at high-way speed and then will re-start by itself, does not do it a lot,,and sometime I get a faint back-fire,, I have noticed that I have a small crack in my vent hose going to the gas tank, would that cause it and also could this be some type of vapor lock, it is weird that you can drive for many miles and it may not even do it,,the truck is a 54 235 engine with mallory electronic Ing........it stalled on the way home from the meet , went from 60 to about 35 and then fired back up and no more problem, thanks for any and all suggestions......Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#43749 09/13/2004 7:49 PM | Joined: Sep 2002 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 62 | Could it be an electrical short somewhere that cut out the ignition temporarily? I typically attribute a sharp stall and restart to an electrical problem. Sputtering and stalling is usually more of a sign of a fuel problem.
Did you have the clutch disengaged when it restarted or was the trucks momentum acting as a starter? | | |
#43750 09/13/2004 7:54 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | 53 chevy, no the clutch was not engaged, it re-started by its on momentum, I think it could be electrical also but would not know where to start..thanks for your response,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#43751 09/15/2004 5:53 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Fred, I'll join with the vote for the electrical/ignition problem.
A sudden and total loss of power (engine run) followed by later restart can, on rare occasion, be the result of fuel starvation. But, that is usually more intermittent and residual fuel will usually allow some irregular running or sputtering.
I don't know nuthin' about fancy electronic ignition systems, so you are out of my league there.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
#43752 09/15/2004 11:24 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Check inside the distributor for any wires that flex when the vacuum advance moves. Those wires have a nasty habit of breaking the conductors inside the insulation, and interrupting the circuit under the proper vacuum and load conditions. The stock HEI ignition was notorious for flex wire problems with the pickup coil, and it's possible your aftermarket ignition system has something similar. Jerry
