9 members (Otto Skorzeny, WICruiser, Peggy M, FAST55, Bucker, wilbur53, GMCJammer51, Forty9, 1 invisible),
63
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | My truck was painted by the previous owner who along with misc parts gave me the paint can that has the info on what was used. The problem is I cannot figure out what it really is, and want to know before I try cleaning and waxing it.
The can says "Sikkens Autobase MM". Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the mfgrs have informative websites, google is your friend .... sounds like it's a urethane base/clear type - or see hereBill | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Bill,
So from the sounds of it this is a base coat urethane. Does that mean it has a clear coat over it? Could it be the clear was never applied? How would I check without damaging the paint? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, that can is from a basecoat, meant to have a clearcoat applied  no tellin what the po did about clear, and I couldn't say how you can determine, but a bodyshop prolly could tell Bill | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I thought base coat is dull compared to a single stage-
I would think it would look very dry without the clear-
My best quess.
Keith | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Yeah, I think you are right. When I look closely at the truck there are a few spots where the sheen is not as great so I assumed I have a base coat clear coat. From there I took a bit of McGuires swirl remover and did not see any color transfer to my white cotton rag, so I am pretty sure the clear coat is in place.
My question now is, how to best fix a few stone chips that I have understanding this is a clear coat set up? Thanks! | | |
