4 members (Otto Skorzeny, J Lucas, TexasA&M48Truck, Ed Atkisson), 86 guests, and 6 robots.
Topics128,021
Posts1,055,373
Members48,420
#437400 07/31/2008 12:12 AM
I'm at the beginning of restoring my 41 half ton, and when I took apart the drag link, I noticed that the ball seats had some deep scratches in them. So to be safe I ordered a drag link rebuild kit from Jim Carter. However, the new seats were ground very rough with noticeable pitting and they had a raised ring around the edge which prevents the balls from fully contacting the seat. They looked a lot worse than the originals. So I was wondering. How do you determine if the ball seats are excessively worn? And balls? And king pins? And spring shackles? Is it not a problem if replacement seats are rough? Will they somehow wear in?
kingisomer #437429 07/31/2008 1:48 AM
I don't think they should be rough at all. As far as wear goes they usually go egged shaped and sometimes have other visible signs of wear.
1951 1 Ton Completed
