| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 3 New Guy | | New Guy Joined: Jun 2007 Posts: 3 | i took the cross members off my frame to sand blast should i rivet it back together or is bolting ok i have a 66 chevy c10 | | | | | Joined: Jun 2007 Posts: 3 New Guy | | New Guy Joined: Jun 2007 Posts: 3 | | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | Bolting is OK. This has been discussed quite a bit on here. Do a search for rivets. The consensus was if you bolt it together, use grade 8 bolts. I would think Loctite would be a good idea as well. | | | | | Joined: Jun 2007 Posts: 3 New Guy | | New Guy Joined: Jun 2007 Posts: 3 | | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i would use good self locking nuts with the locktight.
gotta love old trucks
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Frames have to flex. Therefor they are riveted. The theory behind rivets is that they fill up the hole completely instead of relying on the squeeze of the cap and nut. We use a ribbed carriage bolt to replace rivets when we attach trailer cross members to the side rail. The ribbed shank fills up the hole like a rivet. http://www.imperialinc.com/grp040.shtml The same company also sells a flange bolt which we use in truck frames. We use 5/8 which of course be over kill for a pickup. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Frames have to flex. Therefor they are riveted. The theory behind rivets is that they fill up the hole completely instead of relying on the squeeze of the cap and nut. This is theoretically correct but debatable in terms of practicality in this case. Properly tightened bolts are more than adequate for his purpose and unless the bolts loosen there will be no movement between the parts being held together. I could not imagine the amount of abuse you would have to heap on a bolted frame to cause the bolts to fail. | | |
