1 members (baldeagle), 87 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#437122 07/30/2008 2:13 AM
i took the cross members off my frame to sand blast should i rivet it back together or is bolting ok i have a 66 chevy c10
theboy #437124 07/30/2008 2:15 AM
help
theboy #437126 07/30/2008 2:23 AM
Bolting is OK. This has been discussed quite a bit on here. Do a search for rivets. The consensus was if you bolt it together, use grade 8 bolts. I would think Loctite would be a good idea as well.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
thanks kevin
theboy #437191 07/30/2008 5:31 AM
i would use good self locking nuts with the locktight.
gotta love old trucks
53chev #437195 07/30/2008 5:51 AM
Frames have to flex. Therefor they are riveted. The theory behind rivets is that they fill up the hole completely instead of relying on the squeeze of the cap and nut. We use a ribbed carriage bolt to replace rivets when we attach trailer cross members to the side rail. The ribbed shank fills up the hole like a rivet. http://www.imperialinc.com/grp040.shtml The same company also sells a flange bolt which we use in truck frames. We use 5/8 which of course be over kill for a pickup.
This is theoretically correct but debatable in terms of practicality in this case. Properly tightened bolts are more than adequate for his purpose and unless the bolts loosen there will be no movement between the parts being held together. I could not imagine the amount of abuse you would have to heap on a bolted frame to cause the bolts to fail.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
