3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I was planning to install a 6 lug axle under my '49 but am leaning toward not using it for several reasons. I think my chances of finding a perfect 6 lug rear axle are slim, so I was thinking to just find a 5 lug since I think they're much easier to come by that fit our trucks. But my question is what is the best way besides IFS to convert the front to 5 lug. THanks for the help! | | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | I put a disk brake conversion kit on my front end that is 5 lug. My truck's a '48 1/2 ton. I think there are several vendors that sell the conversion kits. Don't recall now what I paid, because I did that a few years ago. (I've had the truck 12 years, and the brakes were the first thing I worked on.)
My rear end is a 3.73 limited slip rear out of an '86 Firebird. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can also use passenger car hubs to retain drum brakes. That subject has been covered extensively. Howeer, I would do the disk brake conversion as well if I was going far enough as to change the bolt pattern.
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | 1954 Chev car hubs and backing plates will get you a 5 lug pattern and then you are open to choose a matching five lug rear end. If you go this route, you can use your existing master cylinder, lines, etc. With the disc conversion, it gets a little more complicated. See the "Parts For Sale" for a set of 1954 Chevrolet hubs and backing plates that are listed there. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The disk conversion kits are not expensive, but you also have to buy calipers, rotors and hoses.
And you really need to convert to dual master and replumb the brake lines at the same time.
I did it on my '55 1st Suburban about six years ago, so my memory may not be complete, but it wasn't a huge job, just took some time and money. I had already installed a '73 Chevelle rear axle with five lugs under the rear.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Thanks for the help! The disc brake conversion must have slipped my mind, I should have said I wanted to stay with drums. Is it only '54 cars that will swap? I will check the Search again. | | |
