1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43667 09/25/2003 1:21 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Can I start my Stovebolt in the '48 to break in the cam/lifters (and to rule out big problems) with nothing behind the flywheel? Seems the answer gotta be "yes." 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#43668 09/25/2003 2:07 AM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Can't think of any reason why not. I usually break in a motor on a heavy wooden stand before putting it in a vehicle. Never had any problem.
George | | |
#43669 09/25/2003 4:28 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
#43670 09/25/2003 10:55 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, just make sure all the bolts are tight first. You don't want a loose flywheel chasing you around the shop.
#43671 09/25/2003 11:36 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | [img]http://photo.starblvd.net/~Mechainiacsphotos/6-4-1.jpg?i=1067245853&pw=*42C83F72C0F2[/img]
#43672 09/25/2003 1:21 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | Luke, I've been firing engines to test them before shipping them to customers for a long long time, always the regular V8's but firing a BIG V12  , You're my hero! By the way, do You still have the V12? Any plans for him?
Alexandre Garcia
