3 members (TS3600, klhansen, 1 invisible), 100 guests, and 2 robots.
Topics128,166
Posts1,057,012
Members48,458
#435843 07/25/2008 6:08 PM
I have purchased a web type cowl seal for my ’41 and I’m trying to figure out how to keep it in place on the cab’s cowl. Yes each side of the cowl has 3 holes for maybe sheet metal screws. It’s the area between these screws that I’m concerned with. I remember removing all that was left of a short section of the old seal and it seems to me that there was a wire involved with the hold down.
The web material I have has a sort of grove all along the length of one side so I’m guessing maybe a sort of stiff wire may have laid in this grove. This wire would have to be bent into the shape/curve to match the cowl.
Anyone got any ideas?? Was there a wire?? Where to get one?? What to use as a substitute??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
kips 41,
i just removed what was left of the cowl seal on a 41 donor cab i got last week. there was a wire in the webbing held down by some little plates at the screw holes. there were 2 wires one starting on either side of the hood hinge holder bracket. the wires had a loop on the end to start in the first holes on the top of the cowl. i do not know if it is supposed to have a loop at the bottom or last hole due to the fact that part was cut away from the cab i got. the wire is 3/32 dia.
thirtyniner
39 chevy 1/2 ton
48 chevy fleetline aerosedan
Kip,
My 4t6 had no seal whatsoever so I have no comment. However mine had no screw holes at all to hold down seal. I bought a new one at J Carters and there is no provision for screws. I was goin get in place and glue down and close?
Dan
I belive you have the wrong webbing. It should have a wire in it.
The wire goes in the hole on the top of the cowl and is bentover under the dash. The wire on the bottom of the cowl is inserted in to the hole and bent over. Then you should have a threaded J- Hook. If I remember correctly in is about a 10-24 thread. The hook goes into the hole at the beltline and a washer and nut goes on inside the cab and draws the webbing down tight to the cowl. I hope this explanation makes sense.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Thanks guys for the responses.
Turns out that I used only the metal clips to hold the webbing. I did use 31,32,33’s information. I installed the end clips first and used the one in the dent at the beltline to pull the web tight.
I wonder if there were several methods of attaching this seal over the years including a few for replacements
Kip, I did exactly what you did. I think I bought the web and the clips from "Filling Station". At first it seemed like it was going to be flapping in the wind, but after closing the hood, the weight of the hood holds the web in place. That was like 4 years since I installed it and there hasn't been any problems.
I have put the regualr webbing on (no wire) with 3 screws and 3m trim cement. Works well.
Cleon
1949 Chevy 6400
