5 members (52Carl, Mike B, 1955 1 Series, Otto Skorzeny, dt235sd), 85 guests, and 0 robots.
Topics128,155
Posts1,056,868
Members48,456
#435902 07/25/2008 11:19 PM
My truck was painted by the previous owner who along with misc parts gave me the paint can that has the info on what was used. The problem is I cannot figure out what it really is, and want to know before I try cleaning and waxing it.
The can says "Sikkens Autobase MM". Thanks.
all the mfgrs have informative websites, google is your friend .... sounds like it's a urethane base/clear type - or see here
Bill,
So from the sounds of it this is a base coat urethane. Does that mean it has a clear coat over it? Could it be the clear was never applied? How would I check without damaging the paint?
yes, that can is from a basecoat, meant to have a clearcoat applied ohwell no tellin what the po did about clear, and I couldn't say how you can determine, but a bodyshop prolly could tell
I thought base coat is dull compared to a single stage-
I would think it would look very dry without the clear-
My best quess.
Keith
Yeah, I think you are right. When I look closely at the truck there are a few spots where the sheen is not as great so I assumed I have a base coat clear coat. From there I took a bit of McGuires swirl remover and did not see any color transfer to my white cotton rag, so I am pretty sure the clear coat is in place.
My question now is, how to best fix a few stone chips that I have understanding this is a clear coat set up? Thanks!
