4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#43605 11/15/2004 11:52 AM
Junior Member
Junior Member
There is a long spring attached around the outside of just one drum on my '68 stepside. I guess this may be an original as no aftermarket drums have this and I've never seen one on any other vehicle. What would you think it's purpose is?
Too bad the truck doesn't have them on the other drums as I think it's an interesting oddity.
#43606 11/15/2004 12:40 PM
I would say it is to keep the brake drums from making noise.
#43607 11/15/2004 4:12 PM
My 54 has this spring on the front drums. I understand that it's primary purpose is to dissipate heat from the drum.
#43608 11/15/2004 9:40 PM
It was an anti-squeal device, which dampened out any scrubbing noise the brake shoes might make on a brake application. If you really want one, and the drum has the proper groove for it, get an oldtime screen door spring and stretch it around. I can't see an overriding reason to use one!
