| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43556 06/30/2003 5:20 AM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | I was just wondering if anybody who has replaced the radiator in there A.D. p-u w/ either the stock 216 or a 235 would weigh in and tell me if they used a 3 or 4 core and how well it worked.
My 235 powered '49 1/2 ton tends to run a little warm this time of year here in MO if I'm out cruising it around 50 mph or so. Around town and under 40 mph it's fine. I've had the old radiator boiled out but, I'm thinking it may still have a fair amount of crap still hindering the flow. | | |
#43557 06/30/2003 2:50 PM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If you can find a radiator from a cabover,its bigger than the 1/2 and 3/4 ton pickups. Bigger non cabovers might be the same too,only modification needed is trimming of the panel in front of the radiator to clear the bigger top tank. Had one in a 51 3/4 ton and it worked prefectly. Jeff | | |
#43558 06/30/2003 5:52 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | A good radiator shop can re-core for about the same price as replacement. You may be able to fit a 3-row radiator in there also, or at least what my show called a "high efficiency" radiator. Then you have no fit problems.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#43559 07/01/2003 4:46 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I have a recored 3 row in mine. No problems, even running a 180* thermostat. Hottest I've had it was around 200* when I was hauling a ton & a half of dirt at 40.
Fred 52 3600 69 C-10
#43560 07/02/2003 5:10 AM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Here's a related question: Just found out my 50's "ebay special" radiator retains water about as well as a spagetti strainer. Is there a cheaper way to go than a full cost $200 re-core? Am I destined to start over? Help!  | | |
#43561 07/02/2003 5:47 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Maybe someone could drag a decent one along with them when they go pick up a rig in Snohomish as soon as they can get things rounded up and get on the road
#43562 07/02/2003 1:49 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Phatman: Radiators are not inexpensive and they are not overly expensive either. Recore will keep the original top and bottom tanks and the original look. Replacement radiators work fine and look ok on first glance, but the eagle eye will see them as a replacement.
Replacement radiators are around $400
Recore is around $300.
Decision time. | | |
#43563 07/02/2003 2:52 PM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | Actually, Jim Carter has new ones for about $250.00 (3 core) and $370.00 (4 core). I haven't priced a recore job. One thing to consider if you go that route is that you still have 50 (+) year old tanks that way. I've seen the repros, unless your going to Pebble Beach they look ok. I'm just trying to decide between 3 or 4 core. I use a short shaft water pump on the '58 235 (in my '49) with a pusher fan in front of the radiator so I've got a little extra room in front of the engine for a little more radiator. What I'd like to hear is how well somebody's truck runs with a new 3 core (or 4 core) compared with the old radiator. Something like "it runs twenty degrees cooler" or "didn't do squat". would be helpful.
Thanks, Stingray | | |
#43564 07/02/2003 3:03 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Thanks for the input friends.
Kook, I agree that money invested in the right radiator is spent avoiding trouble down the road while retaining the old components...
Luke, I'm not sure I follow. Email me if you like. | | |
#43565 07/02/2003 4:39 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I had mine re-cored for $225. Very happy with it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
