2 members (cmayna, TUTS 59), 164 guests, and 0 robots.
Topics128,113
Posts1,056,612
Members48,450
I
I Offline
GMC 302 motor. Mechanical advance. 2 bbl carb (Holley I think)
I've read a few posts that suggest setting timing with a vacuum guage so that you have the highest vacuum at the highest RPM. I tried this today. The RPM and vacuum (18 lbs) stayed the same over probably an inch of movement of the distributor. After the initial setting it pinged so I turned the distributor clockwise until it stopped. It took about four tries and I probably rotated it 1/2 inch.
Am I doing this right? I don't see how you can set the timing with a vacuum guage when the vacuum and RPM stay the same over probably 20 degrees of rotation of the distributor.
You set mixture with a vacum gauge at idle I have never heard or done it the way you are taking about, I always set timing on my own stuff like you did back off till it stoppes pinging
I
I Offline
I didn't mean to imply that this test was done at high RPM; only that the vacuum and idle RPM both were supposedly highest when the timing was correctly set.
Izz,
Warren is right, you set idle mixture with a vacumn gage, not timing. Do the timing first, then the mixture with a warm engine.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
I
I Offline
I actually had pretty good results setting the timing with a vacuum gauge. I'll admit that the initial timing with the vacuum gauge was far from precise, but in the process I did learn how to time it by ear by retarding until it stopped pinging. I also noticed a significant increase in power from where it was previously set.
hvp Offline
Junior Member
Junior Member
It is OK to adjuat timing with a vacuum gauge.
Here are a couple of links.
http://automotivemileposts.com/garage/v2n8.html
How, and why, to adjust timing with vacuum gauge.
http://www.iwemalpg.com/Vacuum_gauge.htm
Reading a gauge to determine problem
Hugh
