4 members (baldeagle, Jon G, Oswald, 1 invisible), 57 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#433317 07/17/2008 1:02 AM
are these always a bit-h to get in , i got 1/2 in and need help with the other , any ideas ??
care to chat write back
It would be helpful if we knew what kind of vehicle you're working on.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
If this is a split window, you can't install one half and then the other, you have to do both halves at the same time. Even though the glass is split, having one side installed makes it off center a bit and the other side becomes too tight to install.
Paint & Body Shop moderator
Personally I start from the centre and 'work' out along the bottom edge first.In fact I do this with ANY rubber mounted windshield. That way you ensure the centre bar lines up and as 4ontheFloor said it stops the windows "walking" across and making one side too tight. dang
I leave a small loop of cord at bottom centre,use plenty of lube,I use plain glass cleaner. It's best if you can have someone on the outside applying a small amount of pressure to hold the glass in place, while you draw the rubber over the pinch weld.Once you have got the bottom edges in to just round the corners get out and pull the glasses down to seat them properly.Re-wetting the rubber if required. Then continue up and round the top gently patting the windows into place with the flat of your hand. DON'T nono hit the glass too hard or you know what will happen! cry Do this when it's a bit cooler ,not when/if it's too hot. Hope this helps!
Jock (I assume it's an A.D. your working on?)
More pix on Flickr.
Moderated by  ndkid275, Phak1
