3 members (Peggy M, RLB, TUTS 59), 105 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#4343 09/12/2003 1:02 AM
WHAT ARE THE CONDEMING LIMITS FOR THE ID OF THE REAR BRAKE DRUMS?
#4344 09/13/2003 5:27 PM
I FORGOT TO SAY THAT THE DRUMS ARE FOR A 52 3100
#4345 09/13/2003 5:32 PM
I think you are asking what the minimum thickness is on those drums. It might be stamped on the drum, or it should be in your shop manual. The place you take it for truing should know.
54 3100 with 235
62 flatbed dump C60 with 261
#4346 09/13/2003 11:01 PM
The local brake shops here will not turn a drum out any more than 1/16" oversize.
So if your standard drum is 11" then 11 1/16" is all that they would allow before sending you off to find some better ones.
They used to be more relaxed about it ,, but not so in the past 10yrs or so.
