| | | Forums66 Topics128,075 Posts1,055,916 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 10 New Guy | | New Guy Joined: Jul 2003 Posts: 10 | WHAT ARE THE CONDEMING LIMITS FOR THE ID OF THE REAR BRAKE DRUMS? | | | | | Joined: Jul 2003 Posts: 10 New Guy | | New Guy Joined: Jul 2003 Posts: 10 | I FORGOT TO SAY THAT THE DRUMS ARE FOR A 52 3100 | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think you are asking what the minimum thickness is on those drums. It might be stamped on the drum, or it should be in your shop manual. The place you take it for truing should know.
54 3100 with 235 62 flatbed dump C60 with 261
#4346 09/13/2003 11:01 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The local brake shops here will not turn a drum out any more than 1/16" oversize. So if your standard drum is 11" then 11 1/16" is all that they would allow before sending you off to find some better ones. They used to be more relaxed about it ,, but not so in the past 10yrs or so. | | |
