0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#43426 08/22/2002 7:18 AM
My 235 had a oiling problem, but thats fixed oil, to valves now smile . My noise sounds like a throw out bearing howling near top of rpm range, but sounds like its from valves kinda :confused: ...No noise at idle, 30-40 psi at idle cold, about 10-15psi hot.
Any ideals?
Brad
#43427 08/22/2002 2:47 PM
Hmm, I dunno about the noise, but 10-15 psi is way low for a full-pressure 235.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#43428 08/23/2002 3:21 AM
To check the location of your noise get a 6ft. piece of heater or garden hose, put one end to your ear and move the other end around the engine and you can pinpoint the location of your noise.
kdot em3
#43429 08/25/2002 9:49 AM
I have very similar oil pressures running 10-30. Sometimes after a ride sitting at a light I feel like keeping my foot on the throttle a little to keep the oil pressure a little higher. Just a little rpm will raise it substantially.
54 3100 with 235
62 flatbed dump C60 with 261
#43430 08/26/2002 6:21 AM
good ideal on the hose, hard to do going down road though. May replace bearing just to rule out as poss cause of noise. Been in there over 20 years.
Brad
#43431 08/26/2002 1:17 PM
Usually a throwout bearing will make noise at idle, too. Easy way to check is to slightly disengage the clutch. If the noise changes, then replace the bearing. Otherwise, it's a lot of work best spent elsewhere.
Does the noise occur only when the truck is moving, or when the engine is revved up? If only when moving, look to the drive train. If when revved up, probably in the engine compartment. Speed up the engine and get out the hose. Start with generator, water pump, and listen around.
Fred
52 3600
69 C-10
