0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | I'm running throught the 57 chevy truck axle that is in my 53 truck and was wonder about the axle bearings and seals...Bearings are acutually in not bad shape, but of course want to put in new seals. Is there a better bearing or a sealed bearing commonly used or??? The seals say national on them but no part number. Just curious if anone has already done htis or if should hit the bearing books. thanks Hans | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have the C washer kind that the axle rides on the brg. take a good look at the axle for pits. If it looks good & the brg looks good you can use them. You can go over the axle surface with some real fine emery cloth. The only alternative brg is one that rides on a different part of the axle in case the axle surface is scored. The seal should be available at any parts store. National usually has the part # on the seal also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | If the seals say national they have been replaced before. Hit the books for current numbers. There may be sealed bearings that will work, but today's seals are much better than they were 50 years ago, and the original design generally works.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | There is some minor pitting in the axles themselves which I don't like, but not too bad. The axle made it from Texas to Bonnevile last year under the 57 panel truck with a camper grafted to the top...and now in my 53 truck. wouldn't mind a replacement riding on a new area of axle. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The conversion brgs are listed in the catalog now. At one time they were only available at some specialty parts places. Your parts store should be able to look them up but I will look up the part # when I get to the shop tomorrow. I,ve never had to use one but the concept seems good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | The bearings are Hyatt OR1502. Timken has a crossover bearing that I can find if I search using the GM part number 111121 and gives a Timken number of R1502EL . I can't find any specs on the bearing though and it doesn't come up if you search that number through the general Timken search which has all the specs. I assume this is a direct replacement, not a repair bearing. I cleaned the National seal very well and no part numbers, just their name and pat.pend. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The catalog shows the R1502EL rear wheel brgs. for 48-62 trucks. It takes seal # Nationl brand 414045. It doesn't show the repair brg. for that model. It starts in 63. Sorry. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | thanks for the effort, this will get me what I need. much appreciated. hans | | |
