| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43338 09/12/2004 8:15 PM | Joined: Oct 2003 Posts: 14 New Guy | | New Guy Joined: Oct 2003 Posts: 14 | I own a 1961 with a 6, just found a 1963 rust bucket but it has a v8. I don't think this is the orig. engine & trans. Would like to know what I need to remove from this '63 rust bucket to install the engine & trans. in the '61. Any help would be appreciated. Thanks. | | |
#43339 09/13/2004 2:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You should be able to transfer the engine & tranny without much trouble. You will probably need to pull the motor mounts and rear crossmember to use in the 61. Might require drilling new holes for them. A lot of things can be swapped between the years you have.
Fred 52 3600 69 C-10
