| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Well, I did a seach but can't find it now but I wanted to let everybody know and also to say thanks to the two guys that posted a couple of tips on dolly removal and stand. One guy post the plans on building a cab dolly and I printed them out and built one, it is vary sturdy and mobile, vary good plans easy to follow. The other guy posted the one man cab removal process and I modified his plans just a touch ( I use a 4x4 post and cut grooves where it meets the door opening so it wouldn't have a chance to slip) but it worked purfectly. So anyway, thanks to both of you guys and if anybody is planning on removing there cab you should search for these two items the are most helpfull.
Ed | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Did you use an engine crane to remove the cab?
Keith | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Slickriffs,
Yes, I used the engine lift to hoist it off the frame, I put a center groove in the 4x4 then I strapped it down with a tie down strap, I probably went a little overboard with the saftey procedures but thought it might be better than going to the hospital or having the lift slip off the board and having additional body work to do.
Ed | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | yA ..Might be real "BODY" Work
Keith | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I was amazed at how light the cab was when I removed all the bolts, I thought it would be a lot heavier.
Ed | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just how heavy is the cab? Anybody ever got courious enough to actually weigh one? Denny G
Denny G Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I would bet it is not much more than about 100 to 150 pounds, it was a whole lot lighter than expected.
Ed | | |
