9 members (chevy51truck, Gdads51, Woodcmiami, KEVINSKI, Peggy M, Wickedbass, Tinker5, Hotrod Lincoln, 1 invisible),
101
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Just rummaging through my boxes of spare parts and ran across a NOS Guide park lamp assembly for 1958-1959 Chevrolet. Might anyone have the Guide or GM P/N for this light? The end flap on the box that would have this number is missing. I figure these were probably used only on the bigger trucks as I'd think that by 58-59 turn signals were pretty much standard equipment on the smaller trucks. Can someone shed a little "light" on this item for me? BTW, the light is single wire and the connector has only one pin. Also has a perfect lense included.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Can't help you with the part number, but I know that my 1/2 ton has two wires. | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Know the two wire is park/signal light. Also ran across a pair of them that are used. All my books went with the 59 when I sold it.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bruce K, my Canadian parts book lists 898759 as the assembly number for the parking lamp, hope that helps. | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 |
